1211212214216217314
  • Keifus
    Keifus Posts: 4 ✭✭
    I have been having issues with TeamViewer timing out after like 5 minutes I been using the free version and i think maybe someone i connected to installed it commercial and not the private. Can you fix my account back to normal please
  • Tracy1
    Tracy1 Posts: 0 Newbie
    Same issue here. Worked fine last week.....today I am unable to connect for more than a few seconds and then it times out. This is very frustrating as the connection is needed to work from home (and impending deadlines for work are not able to be met due to this new issue). FWIW, I am also in Germany and using a free license for personal use only.
  • urrlich
    urrlich Posts: 4 ✭✭
    edited February 23
    @Tracy1, I think using TV for doing (paid) work remotely is considered commercial use…
    I'm using it to help (mostly elderly) family members and seeing the same problem.
    Regarding the question of paid vs. free, I would gladly pay something like 5 Euros a month to be able to reliably use it with a small number of remote machines for a limited time. Something like 10 machines and 10 hours per month would be enough.
    Edit: I'm in Germany too.
    Edit2: ** REMOVED BY ME BECAUSE EVEN MENTIONING OTHER PRODUCTS IS APPARENTLY NOT ALLOWED HERE **
  • smile_at_me
    smile_at_me Posts: 0
    Same issue here in Switzerland. I suspect this is not related to the country you're connecting from.
  • Darkiger
    Darkiger Posts: 2 ✭✭
    Exactly the same issue for me and I am in Switzerland too. No commercial suspicion.
  • peval
    peval Posts: 2 ✭✭
    edited February 23
    Same issue in Italy, i agree, it does not matter the country you are in.
    Either a fix comes soon or I have to find an easy alternatives like ** Third Party Product **, ** Third Party Product **, whatever!
  • DBquick
    DBquick Posts: 8 ✭✭
    Dear all,
    I got the following message from the support:
    "I encourage all users experiencing this while being 100% sure to not use TeamViewer for any sort of "working" to fill out the form on teamviewer.com/reset. Our team will review every submission within a short time."
    Let us keep updated, if this will change anything!
  • Aaditya
    Aaditya Posts: 0 Newbie
    I have faced the same issue, does anyone have the mail id of the customer support?
    I am a student and I am also using a free license.
  • iamjay
    iamjay Posts: 0 Newbie
    Whenever I try to connect to my PC using teamviewer it shows some license error and says that my account is having limitations for using teamviewer as I use my account for Commercial purpose.
    But this is not the case, I never used my account for commercial purpose or in fact I use TeamViewer once or twice a month, just to connect to my own device linked with same account.
    How do I fix this, there is no option to contact Teamviewer support aswell.
  • Shinx
    Shinx Posts: 1
    I have been using Teamviewer with free license just fine with my family/friend but today when I tried to connect to my friend computer, Teamviewer blocked me saying that "Connection blocked after timeout. Your license limits the maximum session duration to a partner, immediate reconnects are blocked. Please try later of upgrade your license."
    After that everytime I try to connect, it blocks my connection for one minute. If I connect at 15:31, it says "Connections to this partner will be blocked until 15:32" and so on.
  • peval
    peval Posts: 2 ✭✭
    This is strange.
    It happened to me a couple years ago, i had activated the "start at login" Team Viewer option on my windows computer and i immediately received a notification about potential commercial use detected and i could see this notification permanently in the Team Viewer windows.
    Now i see everywhere "free version", so it does not flag any detection
    Is TV support aware of this? do we still need to go for the reset procedure?
  • Heinvomberg
    Heinvomberg Posts: 0 Newbie
    This link wouldn't solve our issues.
    Isn't there anybody from Teamviewer for helping us with timeout issues in free versions?
  • schoofol
    schoofol Posts: 0 Newbie
    Hello I am using the free license (non comercial use only account) until today I had no problem accessing my home computer from my laptop. Today I logged in and then got this message after it logged me out of my PC, "Connection blocked after timeout. Your license limits the maximum session duration to a partner, imediate reconnects are blocked. Please try agian later or upgrade your license".Was there a policy change? I have been using this free account for years with no issues. Thanks for any help
  • Truckeeer
    Truckeeer Posts: 10 ✭✭
    Same here. Timeout after few seconds.
    Server and client are on latest version, Windows to Linux.
  • Same problem here
  • NYBBLER
    NYBBLER Posts: 0
    Even thou the option is off I keep getting kicked from my session after a minute or two. Every update they release has a new problem that doesn't get solved
  • jhchoi
    jhchoi Posts: 0 Newbie
    edited February 24
    I have two accounts. I used two accounts alternately at work and at home. When I use my free account at home, I get a message that I used it commercially. I don't use it commercially at home. Please solve the problem.
    1. [removed per Community Guidelines] -> License
    2. [removed per Community Guidelines] -> Free
  • ivanoantonio
    ivanoantonio Posts: 0 Newbie
    I am using Teamviewer for a long time. i think i have an account since 12 years. I use my actual account since 2015.
    Today i tried to help my brother in law to install a program and I recieved the message that i got disconnected afther 5 minutes and i can't connect more... I found in the internet that connection is locked when there is a commercial use of teamviewer.
    The only people i am connecting to (as you see in the picture below) are: my mom pc , my sister pc , my brother in law PC and my uncle PC ... my personal laptop and home pc... and 2 android TV i have at home.
    Please note Nvidia SHIELD IS REPETEED 2 TIMES but it is only one TV.
    So considering that 3 of those are my personal computers, there are only 4 PC i am connecting to from Poland to my family in Italy. I do not think that it can be considered "commercial use" adding 4 computers in the last 8 years....
    Please help me to unlock the teamviewer free mode. Thank you!
  • Usik_Sviatoslav
    Usik_Sviatoslav Posts: 0 Newbie
    Hello, please tell me why I have a time limit? I have never used the program for commercial purposes and there is no need for this. I log into TeamViewer no more than twice a month. Why am I getting this limitation?
  • sam2ga
    sam2ga Posts: 0
    I am using a free version for educational purposes but it keep telling to buy commercial license due to heavy usage. I just recently wanted to start using it after more than 2 years not using it. How do I rectify it?
  • gustinn2
    gustinn2 Posts: 39 ✭✭
    Dear staff at Teamwiever.
    As i can see here some other users are getting same message like me this here:
    , "Connection blocked after timeout. Your license limits the maximum session duration to a partner, imediate reconnects are blocked. Please try again later or upgrade your license"
    as others here i ask .Was there a policy change?
    For 15 minutes I logged in and then got this message after it logged me out of my PC I have been using this free account for years and couldnt use it for over a month in september when your system thought i was using it for business use, after that i send you through your system pdf document undersigned that im using it for personal use and since then i have been using the service with no issues.
    I need to be able to connect lastly on friday.
    Kindly help me here and now and asap so i dont have to again to be out of using teamwiever for over a month like i had to in august to september last year.
    gustinn2
  • While_1
    While_1 Posts: 0 Newbie
    edited February 25
    I am working in academia and have been using free TeamViewer license for quite some time to access my work computer from home. Today I started getting kicked from sessions after approximately a minute of use. Trying to reestablish connections results in a 1 minute block that gets prolonged for a random amount of times. Once unblocked, I can connect to my work computer once again, just to get kicked and blocked a minute later.
    Please help :)
  • AlexRud
    AlexRud Posts: 0
    I use free plan to connect my personal PC from mobile and laptop. Everything was fine but today it IS connected only on 1 minute and got "Commercial use". How to fix it?
  • montini
    montini Posts: 3 ✭✭
    Same here :(((
  • Lunneborg
    Lunneborg Posts: 7 ✭✭
    i have a free version to help friends and connect to my home computer from remote.
    it worked perfect untill the last update to 15.15.5.
    now i get timeout and it say i need to buy a licens.
    and im locked out and cant reconnect for som min.
    is this a bug or do i have to buy a license and all my friends and family to?
  • Igorb2005
    Igorb2005 Posts: 1
    I have same problem, and i would like to know how many devices must be for free license ?
  • mbacklund
    mbacklund Posts: 9 ✭✭
    I also got this:
    What is going on? 😠
  • Efe
    Efe Posts: 6 Newbie
    edited February 25
    This isn't commercial usage detection right? I only use TV in my home network, I don't even try to connect somewhere outside of my LAN FFS. Why is it happening? I can only stay connected to my other PC for about 1 minute.
  • Lunneborg
    same for me byt my msg say i have to wait or buy a lisence.
    and i timed out to reconnect to the computer for some min and if i try to sone i get extra time out time.
