Read this article in Chinese | French | German | Japanese | Spanish
This article applies to older TeamViewer versions (up until 15.3) on Fedora 29 and higher.
General
Until Fedora 28 TeamViewer is able to make connections without any special configuration of the operating system. With Fedora 29 the Fedora project changed the dbus implementation which affects TeamViewer up until version 15.3.
HintPlease update to TeamViewer 15.4 or newer to resolve this issue.
The problem
Incoming connection doesn't get trough to the TeamViewer client:
The initiator of the connection sees the following error:
The source of this issue is the active dbus-broker service.
This can be figured out with the following command:
systemctl status dbus.service
Solution
The good news is Fedora did only change the default dbus setting and it's possible to change it back without any complications for other applications and services on the system.
Execute the following commands as an administrator:
systemctl disable dbus-broker.service
systemctl --global disable dbus-broker.service
systemctl enable dbus-daemon.service
systemctl --global enable dbus-daemon.service
#Now reboot the system so that the settings are getting reloaded reboot
Realated articles
Version history
Revision #:
11 of 11
Last update:
October
Updated by:
Labels (1)
